Este tópico é continuação do Basic Configs.
Sequência: 02
1) Visualize as configurações das interfaces
NY_R1#show running-config | sec interface
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/0/0
switchport mode access
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
shutdown
NY_R1#
2) Veja outros detalhes das interfaces
NY_R1#show ip interface brief
Interface IP-Address OK? Method Status Protocol
GigabitEthernet0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/1 unassigned YES NVRAM administratively down down
FastEthernet0/0/0 unassigned YES unset up down
FastEthernet0/0/1 unassigned YES unset up down
FastEthernet0/0/2 unassigned YES unset up down
FastEthernet0/0/3 unassigned YES unset up down
Vlan1 unassigned YES NVRAM administratively down down
NY_R1#
3) Veja mais informações de uma interface.
NY_R1#show interfaces gigabitEthernet 0/0
ou de todas as interfaces
4) Adicione um IP a interface
NY_R1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
NY_R1(config)#interface gigabitEthernet 0/0
NY_R1(config-if)#ip address 192.168.10.1 255.255.255.0
NY_R1(config-if)#do show ip int bri
GigabitEthernet0/0 192.168.10.1 YES manual administratively down down
NY_R1(config-if)#
5) Adicione endereço IP a outra interface.
NY_R1(config-if)#exit
NY_R1(config)#interface gigabitEthernet 0/1
NY_R1(config-if)#ip address 192.168.20.1 255.255.255.0
GigabitEthernet0/1 192.168.20.1 YES manual administratively down down
6) As interfaces estão com status administratively down down. Vamos remover o shutdown das interfaces.
Aproveite para conectar as interfaces g0/0-1, a um switch. Para que elas alterem o status para UP. Afinal, é necessário que haja conexão física.
Pode usar um Switch 2960.
NY_R1(config-if)#do show run | sec inter
duplex auto
speed auto
shutdown
duplex auto
speed auto
shutdown
NY_R1(config-if)#no shutdown
NY_R1(config-if)#%LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
exit
NY_R1(config-if)#%LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
duplex auto
speed auto
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
NY_R1(config-if)#
7) Execute um teste de ping e certifique, que a interface esteja UP.
NY_R1#ping 192.168.10.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 192.168.10.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/4/12 ms
NY_R1#ping 192.168.20.1
Sending 5, 100-byte ICMP Echos to 192.168.20.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/4/10 ms
NY_R1#
Este exercício continua em Conectividade
Interfaces
Interfaces
