Configurando Grupo de Agregação de Links - LACP em Huawei NE20
Procedimentos operacionais para diversos tipos de configuração em roteadores e switches.
Exemplo de Configuração: Agredação de Link LACP.
interface Eth-Trunk0
 description L2 Switch DM4380
 mode lacp-static
interface GigabitEthernet0/3/1
 description Switch DM4380
 undo shutdown
 eth-trunk 0
 undo dcn
interface GigabitEthernet0/3/2
 undo shutdown
 eth-trunk 0
 undo dcn
Certifique-se de que a configuração foi aceita e aplicada.
<RTR1-SPO1-BRE>display interface Eth-Trunk0
Eth-Trunk0 current state : DOWN (ifindex: 66)
Line protocol current state : DOWN
Link quality grade : --
Description: L2 Switch DM4380
Route Port,Hash arithmetic : According to flow, Maximal BW: 20Gbps, Current BW: 0Mbps, The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 8cfd-18ef-f6c1
Current system time: 2023-01-07 23:29:35
Physical is ETH_TRUNK
    Last 300 seconds input rate 0 bits/sec, 0 packets/sec
    Last 300 seconds output rate 0 bits/sec, 0 packets/sec
    Input: 0 packets,0 bytes
           0 unicast,0 broadcast,0 multicast
           0 errors,0 drops
    Output:0 packets,0 bytes
           0 errors,0 drops
    Last 300 seconds input utility rate:  0.00%
    Last 300 seconds output utility rate: 0.00%
PortName                      Status              Weight
GigabitEthernet0/3/1          DOWN                1
GigabitEthernet0/3/2          DOWN                1
The Number of Ports in Trunk : 2
The Number of UP Ports in Trunk : 0
<RTR1-SPO1-BRE>
